Navigator/Aviator oem wheels fit on 00 Navi
LB3DR
Fremont
Can anyone tell me what bolt pattern does an 00 lincoln navigator has?
Is there any difference in the 2x4 and the 4x4 bolt pattern?
For the 2003+ Navigator, what bolt pattern is it?
For the 2003+ Aviator, what bolt pattern is it and what size of rims do them come with stock?
My uncle has a friend who is selling a set of 2003+ lincoln navigator or aviator oem rims with tires. The rims are 17", could they be from the aviator?
Because I saw some rims like this on 2003 navigators also.
here is a pic, and let me know if it would fit on my 00 navigator.
If they are 17's they are from an Aviator. 2003 and up Aviator's only came with 17's. The Aviator has a five lug bolt pattern. 2003 and up Navi's only came with 18's. They have a 6 lug bolt pattern. I am positive of all of this. 2002 and earlier Navi's had a 5 lug bolt pattern. The wheels in the picture might be what was available on the 2002 Blackwood as well as the 2002 black monotone edition Navi, I am not sure if those were 17's or 18's though. If you want to know the exact oem bolt pattern of a Lincoln just call the local dealership. Hope this helps!
the 4x4 and 4x2 navi's had different studs. The 4x4 had a 14mm while the 4x2 had a 12mm stud. And he's right about the 5 and 6 lug
I called the dealer and they told me that the 00 have an 5x135 bolt pattern, while the 03+ aviator has a 5x114 bolt pattern.
And yes, those rims in the pictures are 17". I went to check them out today.
Also, I believe the 03+ Navi's are 6x135 or something, but for sure its a 6 lug pattern.
I really appreciate you guys helping me out.
By the way, does anyone know which vehilce these rims can fit on?
Does it fit the F-150s?
