2002WRXSTi
So coming back from a trip to W/C screwing with a friends R6 on Rt22. All of a sudden my engine winds out? So I let off the throttle till I was doing about 20mph.
Turn off the OD and play around but all I am able to get it 1st and 2nd gear. So I cruise home doing around 50mph at 45 to 5000rpm hoping this 209,855 engine holds together?
Got back to my friends house with my coolant light on for some reason? Pop the hood and it is maybe an inch low in the tank. Go out and get some ATF fill it to the full line drive around the block, only hits 2nd gear still but coolant light comes on again? Pop hood and coolant tank is empty. Dripping from center of engine but pump is dry. Seems to be dumping from lower part of block?
Only half the problem anyway seeing as I don't have a trans anyway now
