jjcool00
The only issue I've ever had with my LS since I bought it in February was very similar to yours. I was driving one day, parked in my drive way left the car on, came outside and bam smoke everywhere. I was shocked, turned the car off immediately. Waited an hour and drove it to the mechanic 5 mins away. They came to the conclusion of thermostat, changed it and the housing (since I think the auto parts store by me sells everything in one piece). Few days later, same issue, smoke and high temperature. Took it to the mechanic, he couldn't find anything. He kept it for 2-3 days just to be sure. Weekend comes up and I start driving it and the temp is on the rise again. I take it home and start looking around. I saw no coolant leak, however when I got under the car, near the driverside tire there was some very thin film. Turned out to be a small amount of antifreeze. After looking over the situation for a while I figured out it was indeed the degas bottle. The high temperature coolant return from the thermostat must've caused it to crack. I changed it and the lower hose (which was a bitch) and been running fine since.
