jus hoping there is a simple solution but knowing the LS highly doubt it. so my i press the horn on the steering wheel no noise i hit the alarm and no noise but the lights flash. any ideas ? dead horn? fuse? bad luck?
That would only affect the horn control, yes? So it should still sound when the car is locked.if you're having problems with your cruise control and radio also, it is your clockspring. otherwise check fuses.
I had the same problem...cost me a cool $400 bucks @ the dealership about 6weeks ago....
It was a bad exciter ring? I think I spelled it right and supposedly only the dealership has the tool to remove/replace it. It didn't matter at that point because I had to get my car inspected the next day...I held out as long as I could but no one could remove it..
does anyone know the actual locationof the horn on my model? 2002 V6 because i checked fuse and relay , fuse was blown which i replaced and relay is ok but still no joy on the horn
