bgjersey30
Hello All,
I just purchased my first Lincoln LS 2003 V8.
I got this car at a public auction and it has 96k miles on it.
Since buying the car at the auction "AS-IS" I noticed that there is a very hard kick into the the second gear... so hard that the rear driver side tires spin. This must have been happening with the previous owner because that tire is considerably more worn that the others, but not too bad though.
So my questions are:
What do you suspect is the reason the car shifts so hard from 1st to second gear?
Also I changed the thermostat and housing since the car was over heating and leaking. Much to my surprise there wasnt a thermostat! The previous owner took it out and did not put one back in??? I had a coolant flush at the dealer but now I have no heat. What do you think the cause of this is?
Thanks for all your input.
