Dino'sLSdeuce
2002 LINCOLN LS V8
Here's my audio/stereo mod, using the stock 6''x8'' speaker pods that are located in each door.
For those with a (somewhat) $$ Limited Budget $$ but have an aftermarket amp. (For this mod I used a KICKER ZX200.2 Amplifier 100watts x 2-chnnls.
My reason for this mod, (first and foremost) was because I couldn't decide on which brand/model aftermarket components to buy. So I decided to see how the stock speakers sounded w/ the KICKER AMP. So I took them apart to see what I had to work with and went from there. (2-way) Components, crossover partitioned.
That's when I decided to relocated those tweeters into the A-pillar trim post. Here's some pics...For those of you who are interested; whilst reading this, but would like to see more ''detailed pics'' of how the Tweeters are mounted and/or how they look fitted/mounted from the back of the A-pillar
. Let me know and I'll reply with more pics if anyone is interested...
Speaker Pod disassembly Note
From the front...
From the inside...
Outside Close-up...
Speaker Pod Notes...
A-pillar Upholstery Note...
. . . The rest of my system:
I'm running a 15'' RE AUDIO SXX (Dual 2-ohm) driven by a KICKER ZX750.1 AMP. *When I purchased the amp I ''assumed'' it was stable at 1-ohm (?) I WAS WRONG !!. My mistake!! So I have the Sub wired only @ 4-ohms vs 2-ohms; that is until I purchase another Amp (which I doubt). The 4 crossovers were all relocated to the back trunk sitting in a type-of component rack.
Ohh unrelated to audio... I had a !!Bee-itchz of a time a couple days ago replacing my Degas bottle; Damn, that un-reachable back pinch-clamp!! My hands just couldn't reach it...I ended up ''yanking!! that lower hose off, instead of leaving it on. Unrelated but, Longstory, Short...Overheating problem solved. That was my 2cents and I'm outta here...
From the front...
From the inside...
Outside Close-up...
