HOT ROD LCN
Hello,
Im brand new to this forum, although ive been reading posts on here for about 2 months. You see, Ive been trying to get this 89 lsc 5.0 from my friend for two years now. Its not mint, but has 112k and body is straight. I took it home yesterday, and from then to now, i realize this is the info I need.
1) the car idles btwn 500-1.25k up and down, and then settles on about 800 @ idle.after about 10-15 mins. is that normal?
2) car came with only ignition key, is there a code in trunk somewhere w/#? for keypad? where exactly?
3) rear air shocks pump up fine while car is running, but rear sinks level after a few hours off.
4) windshield needs to be replaced. any warnings? do cougar & t-bird glass work for same yr?
5)there is a noise that sounds like a door open alarm, but higher in pitch, that i cant turn off- any ideas?
6)driver side window motor sounds like its working, but window doesnt move.
Im a newbie to lincolns, but feel so drawn to this neglected mk7 and im trying to give it a second life, even as a backyard hobbyist mechanic. Any input is appreciated!!!!
