Travis2000LS
Okay So I got my 2000 Lincoln LS V8 Sport for 2900$ Tax Tag and Title all included.
So In that time ive replaced : Torque Converter, Timing chain Tensioner Driver side.
So Ive got about 700$ into the car already.
Now driving a few days ago I had a over heating problem
Did some searchin on my car and the fan is good, the waterpump is good, and put a new thermostat.
So now ive came down to the conclusion that its Either a cracked Degas bottle.
Today I did a pressure test on the bottle and couldnt get it to leak as I thought it was doing at the drivers side bottom fender.
But then my mechanic noticed it was leaking a tiny bit at the thermostat Housing. The goose neck part that has about 4 Places for hoses and what not and where the thermostat mainly sits in.
SO! My question is, could this small leak cause a overheating problem under pressure?
and if so.
Ive did some research and found a All aluminum housing for 50-60$ shipped through rock auto.
Ive also found this
Amazon.com: Motorcraft RH68 Thermostat Housing: Automotive
On amazon.
If you could give me your thoughts and tell me if this is the right housing for my 2000 Lincoln ls.
Thanks!
and if so.
Ive also found this
On amazon.
Thanks!
