Motor Mount Question
Lincoln Mark VIII
  1. 93mark8rules
    93mark8rules Active LVC Member
    112
    4
    May 26, 2016
    Paramus
    I have a 94 Mark VIII and the drivers side motor mount, and trans mount are pretty much shot. I get an intermittent thud when I leave a light under moderate acceleration. I called the dealer the original Hydraulic mounts are no longer availible, and I've tried Anchor mounts in the past and they never worked well. What are you guys running? The anchor mounts are the same part number for passenger and Driver could I use a passenger side Mark 8 Mount and just swap the mount into a driver side bracket I figure that probably has to be in good shape?
  2. slowmkviii
    slowmkviii Dedicated LVC Member
    5,543
    124
    Sep 28, 2007
    Elk River, MN
    I just purchased scp solid rubber mounts for my motor as did markviiiedrea.
  3. 93mark8rules
    112
    4
    May 26, 2016
    Paramus
    Does it transmit a lot of vibration?
  4. slowmkviii
    5,543
    124
    Sep 28, 2007
    Elk River, MN
    Mine are not in yet (working on house)
    Eric's should be in within this week
  5. Dee Welch
    Dee Welch New LVC Member
    9
    Jul 27, 2017
    New Jersey
    Anchor mounts are not good enough, tried it before.
  6. 93mark8rules
    112
    4
    May 26, 2016
    Paramus
    So did any of you guys install the new mounts yet? If you did what do you think?
  7. Markviiiedrea
    Markviiiedrea Speed Bump
    4,781
    166
    Sep 20, 2004
    Bloomington, MN
    Can't tell a difference, I just know one of my old ones was junk. I've got a little more vibration but I think it's from my headers and not NVH.
  8. Markviiiedrea
    4,781
    166
    Sep 20, 2004
    Bloomington, MN
    Just don't buy fluid mounts. You'll be fine.
  9. 93mark8rules
    112
    4
    May 26, 2016
    Paramus
    I find it weird that everyone doesn't like the fluid mounts. I'm finally changing the original one and I have 186k on my car. Weird part is its loose intermittently...
  10. Markviiiedrea
    4,781
    166
    Sep 20, 2004
    Bloomington, MN
    I just changed the factory ones after 245k, they work fine but when they fail they motor really flops around.
Share This Page
