Motor mount ground?
warrioralumni08
Oklahoma
I know there is a ground on the passenger side motor mounts, but it broke off on one of the ends, and I was wondering what it bolted up to. Can I just get another ground from a parts store or something?
There is a stud on one of the motor mount bolt locations on the block. Its held on to that stud with a nut. Crimp a new eyelet on the wire and bolt it down in the original location.
The ground then connects to the frame using a 6mm hex self tapping screw. Be careful with that stud they are no longer available. Make sure ot use a 6point socket on it.
Well, K Member is already in the car now, along with the engine. It looks like I am not going to be able to reach that stud, and put the ground wire back on. =/ I found where the other end went thank goodness. Any other places I could install it on?
You can install/remove it with the K member in. Put a socket on a long extension and swivel. Then go through the sway bar opening between the frame and K member. Use a deep socket. I think 13mm.
Well, actually, I took the motor back out today, so now I will have access to it clearly, thanks everyone.
