im having trouble with my 94 mark 8 it started cutting out i checked the fuel pressure and it was showing where it should be, next i did the jumper wire for code test only codes showed it was running lean changed o2 sensor still cutting out, did a cylinder balance test and it showed that 3,4,5, and 7 where not firing right changed coil pack still no change, could it be the injectors or something worse
