dj_jace
So has anyone ran their ls down to 0 on the miles to empty to see if is accurate. Im debating on doing it... with a gas can in the car of course. Just curious if anyone elae has done it.
Yeah I dont normally do this or run it low either. I was just curious if I was in a pinch and not near a gas station if it would be pretty accurate
Fuel in the tank keeps the pump running cooler, thus protecting it from overheating failure. Once you get down so low, you don't know what type of sediments and moisture the pump will be drawing and may result in expensive fuel filters and injector cleaning/replacement. Fuel "floats" on top of water/moisture; the pumps don't draw fuel from the very bottom of the tank, unless you run the fuel tank practically empty. The most I ever let the level go down is to about 1/8 left.
I've ran it down to 1 mile before just as I drove into a gas station. I filled it up and it took just under 17 gallons. I believe the tank holds 18 so it's not too accurate.
I think that it is intentionally paranoid. With just one gallon in the tank, you could get on a slope and have the pump inlets uncovered and be unable to use all of that last gallon. That said, I don't think that my 04 gives that much margin (my 06 does).
... curious if anyone elae has done it.
Almost didn't make it to the pumps this morning.
Put on some much needed go-juice.
