H
HighRule
Guest
I was reading up on the LS options and came across this "Bulb failure warning". Which is supposed to let you know when a light has burnt out. I've never had this message pop up and have had issues with my passenger side high beam. It seems if it's always blowing or I have a short. I've replaced the internal headlight wiring harness with my drivers side harness when I replaced my drives headlight assembly. That harness has never given me problems, so I was assuming it would give no problems on the passenger side.
Boy was I wrong. If the bulb isn't blown I must have a short somewhere before the headlight harness itself. How would I go about tracking this down? I will be doing my coils and other stuff tomorrow if there's no more snow and I wanted to do this at the same time. It could be the bulb, but my driver side is still working and was purchased as a two pack set.
I'm tired of replacing my lights. I buy a new set every time I have to replace the passenger one. Therefore, I have an extra "good" one laying around. I just thought I would check for a short to be on the safe side, to see if that is causing my passenger bulb to blow.
Sorry for the long post for such a SHORT topic.............LMAO see what I did there? Man I'm tired. :sleep:
