Mercon V Overfill of 5R55S Transmission
xford
Newport Beach
2006 LS V8 - If a shop overfilled the Mercon V Trans fluid is the only place it can leak from (without some other type of seal issue, trans cooler leak, etc. problem in play) the Hose that runs from the top bell housing passenger side of the trans to the back near the output shaft?
Thanks!
It's really badly overfilled (and probably doing damage) if it is foamed up enough to come out of the vent.
