jruppert
I have a 2003 and I have been hearing this clunk sound has I drive down the road. I haven't had much chance to jack it up and take a look but I believe it is the lower control arm ball joint. I stopped at a store and let it idle for about 30 minutes and after I left, this wheel make the loudest 'dry' sound and the sound was in sync with any left or right movement of the wheel or any up and down movement of the wheel.
Im pretty sure its a ball joint but wont be 100% convinced until I get in there to check. So my question is, if I were to buy a new ball joint for the lower, does this just come out or is it pressed into the arm? If it is pressed in, then I may just as well replace the arm because I dont have the resources to mess with it.
