Mass Air System
VERY simple install. (should have contacted the provider first since thats what were here for is customer service) Remove stock air box, remove maf electronics, take our housing, re install the maf electronics into our housing.
Then install the housing and filter to the stock intake tube.
One precautionary thing to not is that when you remove the stock electronics MAKE SURE that the small O ring seal comes off with the electronics, sometimes it sticks in the stock housing and then the customer will install the electronics without the o ring and it will cause problems.
In 14 years of selling this item NO ONE has ever once returned nor complained about the product.
Let ONE person whom has our kit chime in and say they had this problem?
I had a problem, It gave me better mpg even with heavy foot syndrome. oh and my car runs smoother and pulls a little harder. It was the worst thing I ever put on my car. lol
When you stick the stock electronics into a bigger housing, doesn't that require a re-tune?
Thats an old wives tale. Its USER ERROR that causes this on re oiling/OVER oiling. LOL Let ONE person whom has our kit chime in and say they had this problem?
never had problem with sensor, of course im anal about things and always keep it clean.
no,it will work fine, better with tunebut ok with stock elec. the lms air kit was the first thing i ordered from geno, then the exhaust, kooks from bill, then geno gave me a deal on the sniper. its a basic tune kit put in what you have and it will write a program based on your mods, including tranny shift points and firmness. if you know what your really doing you can get into a/f ratios & timing, but i wont touch. dynotune is still the best, then custom chip, but i like my sniper can link laptop to car while driving get all kinds of info.:rolleyes:
Im averaging about 2.5 to 3 mpg's more with it.
Hey Geno it's Curtis, is it possible to check the status of my order I received the mass air kit and the stickers, but still haven't received my exhaust kit with tips. Said you sent it out Monday. If you could give me a call Thanks Curtis.
all his stuff comes in from other manufactures all over then out the door.also the exhaust kit weighs about ten times as much, takes a little longer
Geno
Geno, how do you know when you need different calibration tubes referenced in the literature that comes with the mass kit? Is the silencer deleted intake tube big enough to flow what the new housing will? Throttle housing too?
