Many issues started all at once. Wanted to get everyone's thoughts / experiences before.............
Jacob
Greenville, SC
2001 Lincoln LS. 3.9 V8. 127,000 miles. Have owned the car since 2005. Second owner. near perfect condition - no rust. Almost always garage kept, or parked in a parking garage at work. Typically has not been a daily driver.
Up until 6 months ago, ran flawless (as flawless as a Jag based Lincoln can be).
Had an issue with a battery maintainer, which caused relay fluttering due to voltage - but, I am not sure if that lead to the issue here or not. Because that was about 2 months prior to the problem.
Here is what is now happening:
Dropped a new battery in - even with battery charger attached:
When turning on the key to the on position:
-Radio comes on in am - lost its settings (ie no power).
-gauges do a sweep.
-Trip Shows 0
-Fuel shows Empty.
-Anti Theft system flashes rapidly for a minute or so then goes back to a normal state.
-Air bag light on for a moment (normal).
-Advanced track light button glows.
-Keyless entry remote starts working, it only activates the memory seat position on the seat. Does not unlock the doors or perform other functions. Turning the key off, the remote will no longer activate the memory function on the seat.
What does not come on:
- interior lights
- HVAC controls
- MAP / courtesy lights
- Headlights / high beams / Fog lights / backup lights / tail lights / running lights
- Trunk lighting
- Power windows do not work, except for drivers window.
- Power mirrors do not work.
- Sunroof does not work.
- Turning the headlight switch on the digital info displays respond and dim, but no back lighting on the gauge cluster / other displays come on.
- Horn does not work.
- Windshield wipers / sprayers
What seems abnormal:
- After having the battery disconnected for 7 hours, I do not hear all the solenoids clicking when hooking a charged battery up. Its very distinctive.
Moving key to start positing:
- No attempt to Crank - No solenoid clicking observed.
What I have tested:
- The fuses that are discussed in the electrical schematics for the systems that are not working. Tested with multimeter.
- Visually looked at all the PAL fuses. I dont see any signs of blown fuses.
- Tested all mini fuses with a meter they tested good.
- Grounds to boxes and resistance back to the battery grounding point in the trunk. All appears to be good.
- Visually inspected grounds - no signs of corrosion (car didnt spend alot of its life outside or in bad weather. Not located in a rust belt area).
- Tested all relays in the car - showed the same resistance .74. Even changed the order just to see if there was a different behavior. Nothing changed.
Scan tool:
- P1260 engine disabled by PATS.
- Reads engine data fine - ie MAF temp, Throttle position, trans temp.
- Door driver module B2112, B2116,- driver set switch - B1341 power door unlock circuit failure B1671 Battery voltage out of range...
Cluster message center:
- Engine sensor data error
- Door sensor data error
- Trunk sensor data error
- Exterior lamps data error
- Advanced track ok
- AC Filter change required
- Low Fuel level
- oil change required
PATS - I have 2 keys. Both exhibit the same behavior.
- I would not expect PATS to disable everything - it seems like its a effect of the problem and not a cause.
I am narrowing down to 3 things:
1. Defective battery? Seems unlikely, but, even putting the battery charger on does not solve the issue.
2. Fuse that I have overlooked?
3. FEM Module?
I am wondering what I may have overlooked, or perhaps, I overlooked a fuse or relay that may lead to this behavior?
Many thanks :-)
The PATS is flashing a code. Read up on how to determine the code. Yes the PATS can and will stop the car. I would focus on determining what the PATS was telling me first. Your error code says the same thing PATS has disabled the car for some reason.
Next what is the resting battery voltage after the car sits all not and not on a battery charger?
Many thanks for the reply.
The PATS code is a 1 1 - appears to be a problem with the transponder coil, or the connections to it from the PATS module in the cluster.
or a problem with the circuit(s) that power these. So, it appears that its going back to a power issue somewhere - perhaps a relay?
The resting battery voltage is 12.7=12.8 and holds fairly steady. The reason for the battery maintainer is that its not a daily driver. So, the battery tends to get low over the course of several weeks.
Low being like 11.5 - 12.0 volts.
I have a 98 Mark VIII with 4.6l 4 overhead cam. My car rapid blinked the anti theft dash light w/o cranking. I sent my PCM out to have the anti theft function removed but it has been too cold for me to reinstall and reattempt a start. It is supposed to ignore any aspect of anti theft and start the car.
