lug nut help
Wheel Nuts differences
I know this is an older thread, but I was looking at wheel nuts for my 00 gen1 v8 17" stock wheels since I have one that is just a regular looking nut (you know the threads sticking out the top) and what I found at autozone was the dorman 611-229.1 call out for the ls, and in the threads here folks talk about the 611-117.1 which is for a chrysler. The differences are, the top nipple is a bit broader on the 611-117.1 than the 611-229.1 and the overall length on the 611-117.1 is a tiny bit shorter, one is SS the other is chrome and one calls out flanged nut the other is Mag nut. BTW the SS are more expensive.
The photos show a knurling on the 117 with a longer distance between the washer and the wheel facing end.
picture.php
611-229.1 specs:
Part Number: 611-229.1
Weight: 0.17 lbs
Notes: AutoGrade (bagged)Flanged - stainless
Callout Size: M12-1.5
Color/Finish: Stainless
Length (In): 1.47559
Lug Nut Style: Flanged Nut
Material: Steel
picture.php
611-117.1 specs:
Part Number: 611-117.1
Weight: 0.15 lbs
Color/Finish: Chrome
Length (In): 1.456700
Lug Nut Style: Mag Nut
Material: Steel
Question is, does any body have thoughts on the difference between these two items from personal experience?
if this helps anyone, i always used my "well used" 3/4" impact socket on my ls (or any car with similar wheels) opposed to a 19mm and find that it works well for the most part.
picture.php
611-229.1 specs:
Weight: 0.17 lbs
Material: Steel
picture.php
611-117.1 specs:
Weight: 0.15 lbs
Material: Steel
I use the 611-117's on my 06 with Jag Senta wheels and they work perfect.
