LS Window Again
heyjewel
auburn
Hey all. So my 2001 manual LS is due to be back on the road. So I got in and drivers window would not go down. Oh man not again. So I ordered another window mech from rock auto and yesterday put it in. And drivers window still wont go down. So I gotta run check on wiring etc. Hope it's not the DDM cause replacing wil require programming? Anyway so far I checked the 20amp fuse in the trunk but it's good.
I bought a window mechanism from a local auto parts store when mine broke it lasted 2 days and it broke. I was in Las Vegas at the time and there's little shops that fix the original factory ones so I tried that and it's been working ever since, the window switch might also be bad, you should test that as well.
Thanks Sultan. I've been unable to do anymore work on it due to weather and me.
SultanGris, what is the name of the little shop in Las Vegas that you used to fix your window? We replaced our front passenger mechanism and it lasted a short time and now is stuck up. Thanks.
Usa auto glass I think, corner of flamingo, Nellis and Boulder, they had a skinny but longer lot,
