lockman
I have a 2005 3.9L, 85,000miles. I haven't had any problems with it running hot until last night. I had started it and let it run about 15 minutes to warm up, then drove it about 15 miles into town to get something to eat... no problems...
After I ate, was headed back home and about half way there, my warning light came on and the temp gauge was at about 3/4. Within just a few seconds it was maxxed out. I pulled over, popped the hood, and steam and coolant was spraying everywhere.
I let it cool down for a few minutes, after some of the coolant had dried it was still wet around one of the hoses, so i went to look at it and it wasn't connected. I've been reading and it appears this hose is the "throttle body heater hose", its a small hose on the "coolant outlet pipe".
I got some pliers to relax the clamp and put the hose back on, filled it up with water, and started it back up. The temp gauge never got above the normal, half way mark all the way home. After i got home and it cooled down, i looked but couldnt find any leaks anywhere. I pulled on that hose and it was tight.
Is there anyway this hose just worked itself loose? Could something be clogged and the pressure blew this hose off? If it makes any difference, I turned the defroster on about 5-10 minutes before this happened.
Thanks for any help.
