For Sale LS OEM used rear upper / lower control arms 2003
Jtown
Franklin TN
Arms are corrosion free. and original FoMoCo parts. As you can see they will need new bushings and ball joints pressed in.
Thought maybe someone could start with spotless rear arms. From 50k car always NC.
Just pay shipping and $40 for packaging and my time to process.
FALSE !!!
While new bushings can be pressed into the lower control arms... the upper control arms are NOT rebuildable !
There is no replacement ball joint for the upper arm... and no way to replace the ball joint. Plus the bushings for the upper arm are VERY hard to source. This goes for the front upper control arms too.
Cursed LS. Didn't realize the limitations as I read here guys trying to insert new bushings on control arms. Agree with what you say though. I'll recycle these. Helps clean out my garage. Will delete the post. Too much old stuff here.
Thanks.
No problem. I have my own collection of LS control arns too.
With the price of scrap down... its itt worth the gas for just the upper arms.
There's nothing wrong with selling the lowers if someone is willing to re-bush them... unless they do a crappy job trying to make a quick buck on resale
