PetesSweets86
Just had a random thought in my mind or it could be that when I filled up gas this morning with premium being 3.00+ per gallon and Diesel being 2.30-2.50 per gallon I had to think. Couldn't our engines be converted to run on diesel?
I've already done a little research and looks like it would cost just the same amount as purchasing the supercharger kit from LLSC.
Another reason why our car could most likely do so is that a diesel engine NEEDS a high compression ratio because it uses the temperature of the engine to burn the fuel properly. Our engine have a VERY high compression ratio and I dunno if I'm mistaken but I'm sure there was a Jag S-type diesel being sold in europe and since or engine is very similar..there are possibilities.
Anyways throw your thoughts out but the extra 100-200+ lb ft of torque would be fun to play with. We'd double our fuel economy (Though I think the V6s will have it better) even the V6s would be seeing 400lb ft of torque since the mercedes 320 bluetec can get that and our V6s aren't far off.
