Triojeepy
Hello Gentlemen, I know this topic has been covered many times over the years and the old threads have very been helpful.
My LS: LS 2000 3.0L V6, 91K miles.
Repairs over the last 1-1/2 years: Replaced all COP's, radiator, compressor, DATC (refurb), DCCV.
Upcoming: SRS light is on (clock spring?), steering column sometimes makes strange grinding noise when turning the wheel at startup (also clock spring??), instrument panel starting to light up like a Christmas tree
So here's the current problem:
I installed a new (refurb) DATC a month or so ago to finally get heat and air after having a dead system for a while. The A/C and heat worked perfectly for a while then I started getting cool air on the driver's side and HOT (not warm) air on the passenger side when using the A/C. When driving it alternately goes from working fine to the Driver-Cold, Passenger-Hot mode seemingly at random. The self-diagnostic returned a 1265 fault code, which is I think (?) is consistent with the Gen 1 LS. Fault code 1265 is the Cold Air Bypass Door -- Ford calls the part the "Door Actuator" (P/N XW4Z-19E616-BA). There are no other fault codes, all else being equal is replacing the CABD the best place to start or are there other troubleshooting areas I might look into as well for this issue? I searched online for the diagnostic Pinpoint Test C for the LS 2000 but could not find it.
And here's another potentially dumb question , how many bypass doors are in the system -- is there just one or are there multiple, and how would I know which one is bad if indeed that's the problem?
As always thanks for the wisdom and tips in advance!
