chump2825
what is the best lowering kit to get for the lincoln? is strutmaster the best?what do i need for a full conversion kit nd how much
67Continental said:ray's lowering kit, sensor mod, or module 8 are the best lowering kits for the mark![]()
chump2825 said:what is the best lowering kit to get for the lincoln? is strutmaster the best?what do i need for a full conversion kit nd how much
turborich said:Why would you stab the bags and cut the wires? why not jack the car up, then turn the air ride switch off, when you lower it back down the car will be on the ground. or just snap off the air line connector? just unplug the wire connector? That way you will still have the parts and you can go back to air in the future if you want.
hytek said:strutmasters is what i got....although through the streets of chicago, its a little rough and i bottom out every now and then. i have to take small inclines at an angle. but highway driving is beautiful! i had mine swapped out in about 3 hours, i cut the bags and wires and went from there (did it at home in my garage). i got mine for $395 including shipping...not a bad deal!
btw...would anyone know why the rear end would be a little higher than the front?? i never switched out the back shocks, should i??
turborich said:Since we are on the topic of spring conversion kit, who makes a 3-4 inch lowering kit?
