lowering springs
lincolnls05
Tucson
i was wondering about the sprint lowering springs and where i would be able to find some to buy. also another question i have is i hear there are v6 springs and v8 whats the diffrence and will they work for my 05 ls its the v6. also i have 20s on it so im looking for the best slam any help is greatly appreciated i tryed searching for a thread on em couldnt find so thats why i posted this thanks
Idk about the difference between the springs are but I can tell you that sprints won't work with 20s. They are close with Andrizzle's 19s. If they do work, you would have to go very very very slow while turning or your fender will be on the ground and you will be in tears.. ;)
This has been covered many times and there is a current thread going on now. You can go low with 20's but you better make sure you have the correct offset.
Ah yea, if you don't won't any rubbing at all. If you have the wrong offset you will rub with any size rim. Ask some of the people who are lowered and haven't done this and ask them if they rub. If they don't then it's because they have the proper offset so the wheel don't stick out as much and don't make contact with the fender. Rolling the fender is an extra step to make sure that you don't rub the fenders. Proper offset will reduce the chances of this and choosing the right width on your tires.
