Lowering and fixing suspension questions
myfirstlincoln
Whitehall
I have a 2003 sport with 100,000+ and nothing has ever been replaced on the suspension (as far as I know). I'm getting clunking and squeaking from somewhere at low speeds when going over uneven pavement. I have already brought the poly sway bar bushings as I'm sure mine are shot and I was planning on replacing shocks on all 4 corners since I'm sure they're due anyway.
I looked on Rockauto and they have:
MOTORCRAFT Part # ASH81
w/ Standard Suspension; Rear $88.79
MOTORCRAFT Part # ASH82
w/ Special Suspension; Rear $88.79
MOTORCRAFT Part # ASH78
w/ Standard Suspension; Front $90.79
MOTORCRAFT Part # ASH24480
w/ Special Suspension; Front $126.79
Anyone care to educate me on the "special suspension" or point me in the right direction?
Since I was planning on replacing the shocks, I was also planning on lowering with Eibachs while I'm at it. Will I need anything else other than the 4 shocks and 4 springs? Thanks in advance!
Part Number/Description------------ List----- Net
3W4Z 18124 DA :SHOCK ABSOR---- 119.97---89.98ea
Part interchanges with part# ASH80 V-8 frt
3W4Z 18125 BA :SHOCK ABSORB-----116.22----87.16ea
Part interchanges with part# ASH82 V-6 or V-8 rear
3W4Z 18V124 A :SHOCK ABSORB------167.73---125.80ea
Part interchanges with part# ASH24479 V-6 frt
Since you're replacing both springs and shocks, and paying for OEM quality parts, I thought I'd leave this here..
http://www.lincolnvscadillac.com/showthread.php?t=76068
This would probably be my plan^^
Staff online
