I picked up a 04 Cobra radiator for my 95 Mark VIII, which lower hose do I use for those running that set up? The lower outlet on the Cobra is 1 3/4", Lincoln rad is 1 1/2". Thanks.
I wish I had a part number for you, but I just went to a local auto parts store and picked a molded hose off the rack that looked like it would work.
FYI, you may need to clearance the K-member slightly in the vicinity of the lower hose. This is the best pic I have of that at the moment. You can see where I removed material at the top-right of the pic:
