#Jeff504lsv8
2005 v8 crusing around under 2k rpm motor feels like a miss but no miss fire codes an injectors are firing like there suppose to i just changed the tps because it started to not want shift until around 3500k to 4k rpm just normal driving an if you really babied it when it would shift from 1st to second it would bog like it wasnt ramping the timing back it. So i changed the tps it did solve the high rpm shifting just normally driving but the bog is till there an the jerkyness is still there when im crusing around 45 to 50 mph under 2k rpm any help will be appreciated. Thanks in advanced
