Low Engine Oil indicator on 95 Mark VIII
calalli
Uniontown
I noticed this morning for the first time the panel display indicated Low Engine Oil. I checked the oil which was fine. I just bought this car 2 months ago, had the oil changed immediately and there are no signs of leaking or burning. I did find one post online that said this light would come on if a remote starter is installed incorrectly. I did have one installed recently so I would like to talk to the installer about that but I need more information. Does anyone know anything about this?
First post here. Great forum, I have been reading and learning a lot.
cal
how much oil is in it? it holds 6 quarts.
if you know the oil level to be good, it is possible that the oil level sensor is simply going bad, or intermittent.
do not rely on it 100%.
Thanks for the response Chris. After a few days I see that the indicator only comes on when I have used the remote starter, pointing to a problem with the install. I will contact the vendor about it; just wish I had more information to provide them.
