low coolant light
PHIL ANDERSON
MELBOURNE
the low coolant light comes on if i drive in town alot but the temperature never rises and the system is full. any thoughts?
the tank is always full, i think its the sensor didn't know if it was common or not. i assume the sensor is in the tank?
I had the same problem a while back. It ended up being that I had too much water and not enough coolant. If there's too much water in the overflow tank, the sensor float won't float. I drained the system and put the correct amount of coolant in and problem solved. Just a suggestion.
