feeninpeece
My current to-do list:
1. Fix all engine related shit and test before sc install
a. Belt tensioner(my belt tensioner flaps around)
b. Timing chain tensioner(classic)
c. Valve cover gaskets(burning oil smell at high rpm, also lately noticed a leak on passenger side)
d. Finish Spark plugs(theres 2 originals left ima lazy mf and theres no misfire so its fine for now)
e. Fuel filter
2. Compression test
3. Clean and paint all sc-related components
4. Disassemble intake assembly
5. Testfit sc assembly
a. Create bracket between lower manifolds to secure sc
b. Create throttle body adapter or drill into inlet from aj27s and match tb mounting holes
c. Take pulley offset measurements (Basically this engine has a double layered crank pulley that goes directly to the blower pulley. Dwiggy emulated this. Im going to design and turn an oversized, offset center pulley that will cancel out the need for this)
d. Measure crank pulley (To figure out how large the blower pulley must be)
e. Take measurements for idler bracket (Gonna make a braket like QuikLS's)
6. Fabricate pulley and idler bracket
7. Take off front bumper and find intercooler location and size.
8. Install Intercooling system (I'm using the stock water-to-air intercooling system in the jag engine, but giving it its own radiator; keeping it separate from the engine's coolant)
9. Make switch panel: ( so you know how every time you try to tune, you need to pull out a bunch of fuses? I've narrowed it down to just the ones below. I'm going to create a switch panel and put it in place of the ashtray/seat heater thing. Basically when i want to tune, I can just flick them all off and then the car will be pretty much disabled and ready for tuning. The duplicates mean multiple fuses.
a. Intercooler pump
b. (future) Vacuum bypass solenoid to disable sc
c. Radio
d. Abs/tcs
e. Cluster
f. Rcm/alternator lamp
g. Radio
h. Fem/cluster/brake interlock
i. Fuel pump
