Lincoln MK VIII FS
MarkOfDeath
IL
My 1994 Lincoln MK VIII with 13XXXX miles, trans is acting up and its just been sitting, I need it to go, its got a new fuel pump 255lph, new front struts, compressor, spider valve, 2 pod a pillar gauges, 3500 stall and dual exhaust with an h pipe, also a SCT Chip from lonnie at blue oval chips, im asking 1800, it just needs to go
note the car is LOw cause it has Rays kit and it at a car show air ride works fine
PM me for my cell
Yeah, could you elaborate on the "acting up" description a little more. I might be able to talk a family member into buying it.
the trans was poping out of third and going into neutral, this happened before, I believe it is the MLPS plug coming loose, because it happened after alot of snow, then i checked all the connecters and disconnected the battery then it worked fine for 2 months, then it happened again and It was -20 outside so I bought a new car instead of working on my lincoln, plus I know longer have a garge or tools since i moved out
