Lincoln mark v111 coil conversion
jetfreak0
Hartford
Hello all.Just finnished installing Strumaster front coil conversion.Plugged airlines as instructed.Still using rear air bags.Tied up air lines and plug for solenoid.Lowered car back down.Went to trunk.Flipped air ride switch back on.Started car.Compressor did not kick on.Do I have to plug solenoids back in.Did not say so in my instructions.Called Strutmaster multiple times today.They have not returned my call.Can anyone help me.Thanks to all in advance.
Regards,
Walter
It wont since it does the fronts first. Since those are now disabled, so is the air-ride for good. A search here would have given you that warning. Also tying up the air lines will not seal them.
The airlines are sealed with screw and epoxy.Airlines are tied out of way.So you are saying plug solenoids back in plugs.Thanks for responce
Hooked front solenoids back up.Compressor kicked in.Pumped up rear air bags.
Problem solved.Thank you.
Good. Keep the switch off now and hopefully your rear bags don't leak. You must have left the front height sensors attached. Do not take them off! If you do, then for sure it will not work right.
