lincoln ls led conv
iivan
Cali
ok i wanna swapp to led...how can i sawpp the dome light? its hard!! aswell for the visor light....also on my reverse led , i see like 2 lil led still on?? how can i fix it? thanxz!
My led reverse lights go out completely after about 30 minutes. They hold some residual power than can be correct by installing a resistor. I have no clue how to install it, so someone will chime in.
I had a Mercury sable and they had the same visors
Best bet is to take it down and there are very small openings around that you can use a very small flat head screw driver on to pop it out... its tough but doable. I did it on my Sable but I don't think I will do it on the LS
same here, about 30 minutes.... as for resistors 1) i have no idea what resistor you would need maybe alax7 or andrizzle will jump in here but you can buy resistors at radioshack 2) as for wiring, you'll have to splice into existing wires most likely but im not sure which ones exactly, i'm actually pretty sure most people here have just left it alone since its not really hurting anything
