Lighting questions
pudgy234
Providence
So i plan on doing some lighting mods in the next few weeks. I want to upgrade the to HID's and change the rest of the bulbs to LED's. Is there away around getting a "bulb out message" on the message center.
And putting what bulbs where will cause these possibly messages
93 Mark 8
93 Mark 8
The only message you'll get should be for the HID's being installed. LED's shouldn't give you any problem on a 93. With the HID's, you'll only have one wire to snip and it's under the glove box on the lamp out module. Brown wire with a light blue stripe. When you get that far, let us know and then we'll get you worked out on the message for the HID's. It's a 5 min fix.
the interior LED bulbs will not give you error messages.
but if you plan on exterior LED bulbs, specifically the turn signals, those will anger the message center. yes, that message can be killed as well. more wire snipping.
