Lift Kit
restince
Phoenix, Arizona, USA
I am planning to add at least 2-inches of ground clearance on my 2013 Lincoln MKX. I am currently checking out cheap lift kits. Are there any aftermarket suspension lift kits for my MKX? Any recommendations?
04_Sport_LS
Somewhere around Lake Erie
Why in the f*** would you want to lift a passenger car??????
All you are going to do is mess up the handling of the vehicle... cause premature suspension and tire wear... and it will ride like shit.
Plus.... I doubt you will find any direct "bolt on" compnents. Everything will have to be custom made... and you will probably have as much or more $$$ into it... than the car is worth.
If you want a lifted passenger car... look for an AMC Concord or Eagle. They are even 4x4.
04_Sport_LS
Or ... if your plan is.to lift the vehicle enough to put "22's" on it, (or 25's... or whatever), go to a shop in your area that does the "hydraulic" installations.
But again... you are going to have more $$$ into the car than what it's worth... and it's going to affect the resale of the car... and you will have to pay again if you have the hydraulics removed.
