So, I'm replacing the Left Upper Control Arm and was able to remove the bolt next to the air filter but the bolt on the other side is impossible to get to (both attach to the body of the car). I've removed the canister purge valve but that has not added that much space. I'm about to remove the brake booster but I thought I should check how you guys tackled this...or remove the degas bottle??
thanks in advance.
thanks in advance.
