xTHANATOPSISx
Came in to find my car surrounded by an ocean of tranny fluid. Got it up on the lift and have found that the leak came from the shift rod, where it come out on the driver's side and enters that shift selector/sensor piece. Looks like the fluid leaked into the electronic piece and came out the electrical plug on the front of the unit. That appears to be the issue anyway.
My first thought is to pull that unit off, clean it out with contact cleaner, clean the shaft and replace whatever o-ring or seal is there and reassemble it and top up the fluid.
I don't know for sure, but I'm suspicious that, because the car set while I was doing some other work on it, when it fired back up after sitting, the o-ring, if that's how its sealed there, probably stuck to the shaft and tore with I started driving the car again.
If someone knows better than I do, and can save me some time by correcting me, I'll be happy to know. I'll rip into it in a few days time, but I figured I'd collect some ideas before I get started.
