tyhackman15
I decided to make a little write-up of how to install a single din H/U in a 2005 LS
First disconnect the battery.
Step one: Remove vents above stereo. I used a flat blade screwdriver to release the clips, then it pulls straight out.
Then unplug it..
Step two: Remove plastic surrounding shifter. Used a very small screwdriver again..
Remove it..
Step three: remove ash tray/cigarette lighter. Two 7mm (i believe) bolts and two screws
...then move it to the side
Step four: Remove the four (8mm) bolts holding in the radio/climate controls
Top:
Bottom:
Remove/unplug Radio and climate controls:
Then unplug it..
Remove it..
Top:
Bottom:
