Just so you know.
Yep, I almost ordered them, but took a closer look at their shapes because they seemed a bit off.. they are not "custom" fit by any means, just an average universal POS mat. Went with Lloyd Rubbertite instead, pretty darn good fit.
those look good M4rk, almost like these?
http://www.ebay.com/itm/230675784343?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
how much did they run you?
I just got these off ebay for $30 shipped, brand new:
Prob not the best for the upcoming winter months lol but i want to switch to black carpet at some point so for the price i couldn't pass them up.
On a side note, why is it that none of these replacement mats have the ring for the front passenger side?
Wish I would have seen those, nice pick-up.
My factory's one don't have a hole either. I don't think there is a hook on the passenger floor like there is on the drivers. Mine is a Gen I, not sure if Gen IIs are different.
Those look superb, where did you order them and how do you like them now after living with them?
I got ripped off here in Canada, as usual.. like $150 shipped. In the USA it's around $89 for a full set, the prices seem to be set by Lloyd. They have a set of authorized resellers on their site too.
Hawk is right, I don't think the passenger side of the car has any hooks. I believe they are on the driver's side to prevent the mat from sliding up and jamming under the accelerator pedal. Wish Toyota would have thought of that huh?
See above. I like the fit, although I wish the fronts were a little wider in some areas, namely the inside curves of the footwells. Otherwise they are nice and heavy, definitely not some junk thin rubber. The only real downside is how bad they smell out of the box. I tried everything in an attempt to get rid of the smell, when finally using Mr. Clean worked. I soaked both sides in the solution for about 15 min per side, and scrubbed. The smell was gone, but returned a tiny bit after about two weeks. My nose is too sensitive..
My LS does have the hook for the passenger side, and my mat has the ring :confused:
and do you mean the rubber smell? i love it :D
I got the same ones mark does. You can also find them under the name hexomat and they have that same cut. Mine are gray since I have dove gray interior and yes they are heavy as hell and trap liquids well. I use mine all year.
i don't think they're the same. I linked the one i think you have above and those have hexagonal shapes, while M4rk's are circles.
The Gen2 has the passenger side retaining hook, Gen1 does not.
They're the same minus what you said hexagon shapes instead of circles. Same concept they are cut to fit as well.
