cammerfe
Agreement and added thoughts
I'm completely in agreement with your thoughts on sound. After all it is a Lincoln. I'm satisfied with the audibility of the Magnaflow cat-back system and the LSK induction system as a combination. When I put in the 4.0 Jag engine, I'll leave the cats off and build pipes to fill in. That'll probably make it somewhat louder when 'on it' but that's all right. The Magnaflow 'X' smooths out the exhaust pulses and removes the raspy component in what you hear. And a pair of turbos instead of the mufflers will make things even more interesting.
By the way, as general info, in performance you're looking for approximately 70%-80% of intake flow for the exhaust. That is when you are doing flow-bench work and 'massaging' the intake and exhaust tracts in the head. Then you extend that comparative flow on outward through the entire intake and exhaust systems. 'Balance' is not 50-50.
KenS from Ben's Place
btw... I agree... I've had mine for a little over a year, and I just find myself wanting a touch of a growl when I get on the gas.
But, I'm of the mindset that as a luxury sports sedan... it shouldn't be a loud rumble. So here I am, over a year later, still debating on changing the mufflers or pulling the resonators. Worried that what I do will end up giving it too much sound. I'd rather have not enough, than diminish the classiness of the vehicle with too much.
Maybe Gibson has some mufflers; their exhausts are pretty quiet...
