jmod?
crownvicjim
hayward
should i do the jmod myself or is there a benefit to buying the valve body from blue oval chips? i dont want to mess anything up.
anyone have the blue oval valvebody? how do you like it?
thanks.
Are you talking about drilling the seperator plate? Drilling it is real easy to do. Just take your time to be sure you use the proper drill size at the correct location. The plate is soft steel so no worries.
Replacing the accumulators can be a challenge if you don't have large enough snap ring pliers. Be sure you get the large size.
I can't see how you could go wrong with Lonnie's kit either. It certainly is priced reasonable, and also includes advise for springs and includes the accumulators too. Just a matter of comfort for you. Just gitter done you will happy with the results.
