the jmod takes 10 minutes?
I bought one that had been profesionally disasembled, cleaned, jmioded, and reasembled.
hey guys while we are on this subject of our 4r70w trans,,,my 93 markVIII chirps(gets rubber)the tires when I shift from first to second myself when getting down,does it mean I have a jmod already or need one someone said my accum.needs to be replaced??trans seems to work fine
sounds like your 1-2 shift accumulator spring is broken
Which means your trans will likely fail w/out any warning if you keep leaving rubber on your 1-2 shift.
Then you'll be cruising around in first gear unable to shift trying to limp the car home until the trans gets hot and you lose first.
