Issue: Auxiliary Outlet / Armrest Center Console
Eurythmian
Arlington
The Auxiliary Outlet inside the Center Console Armrest seems to have stopped working.
I've also notice the light under the lever to the Parking Brake doesn't light up anymore either.
But the Parking Brake does work - and the Auxiliary outlet under the Climate Control still works.
Any ideas?
:confused:
Are those both on the same blown fuse? Possibly a connector just worked loose in the console.
the pannel with the cup holders and the parking brake pops straight up.
a fuse is more likely
Any ideas?
:confused:
I assume you mean the night time illumination of the parking brake switch, and not the "service parking brake" warning light. Does your traction off or advancetrac off (whichever you have) switch work? If not, then it is likely to be a shared ground point (S320 in particular) that is disconnected. Any single fuse that would stop both the light and the power point would also stop several other things in the car (like all of the dash lighting).
I have an 05 LS with everything(THX,NAV), at least I thought I had everything. How did you get a factory aux input?
