LS_is_my_girlfriend
I have a 2002 V6 LS with a manual transmission, this Saturday night I was merging off the freeway and I couldn't get it into 4th gear out of 5th. I also noticed the clutch pedal would hit the floor with little resistance, I could get it into gear if I jammed it, but it wasn't grinding gears. So something tells me the master went out, I had one go out on my old 4x4 Ranger a few years ago, very similar.
So has any one replaced the master clutch cylinder, and how hard is it to get to, its pretty tight by the firewall and I didn't see it back there. I found some instructions online that tell me I need to drain the coolant and brake fluid... but that doesn't make sense to me. The clutch and brakes don't feed from the same reservoir do they?
Any insight would be greatly appreciated.
