jdforsberg
How do you replace bad door sensors? I had a Lincoln dealership replace both about two years ago but now the drivers side is bad.
Thank you. It worked so far. Lincoln dealership wanted to install a new one.driller said:Probably just need WD40.
MonsterMark said:'Door Ajar' messin with your brain? A little spray lube will help keep you sane.
