interior lighting issue
billy hicks
tonica il.
Here is the problem I'm having on my 98 lsc. If I unlock the car with my factory remote all interior lighting works as it should. If I use keyless entry pad on drivers door, or the thumb switch on dash,again,all lights work as they should. Problem is, if I open either drivers or passenger door no lights come on,also opening either door will not shut off radio or wipers,or bring up a "door ajar"alert on my message center.To me the obvious would be door switches,however both have been tested and are good,even replaced them anyway to be 100% sure,even used a jumper wire at door switch plug to bypass switches and still nothing. Any suggestions,SCIL module? Im stummped
