intake help
topher5150
Grand Rapids, Michigan
so i got the cobra intake put in, but the upper part dosen't clear, the big fuel pressure regualtor and somthing at the end of the fule rail are sticking up to far. i was told that the stock fuel rail would fit. :confused: :confused: :eek:
Its a gen 2
I'm having trouble posting pics. Its the vac line on the fuel rail on the left side. Its smushed under where the cobra EGR would go. I was thinking mayb I could trim the EGR port on the manifold. Also what is the best way to rig up the throttle cable brackets
i trimmed mine back but I TOLD YOU !! you have to get a cobra fuel rail unless you want to modify. as for the throttle cable, just try to make it work. improvise..
