Inside Auto Lamps
Clean00LS
Clinton
Does anyone know how to change the inside of a 2000 Lincoln LS auto lamps? If so please let me know!!
Also how do you check and see what color sealment I have on the headlights to be able to change to a clear corner?
You mean the headlight, if so, search the forums. You can see the sealant at the tabs on the headlight where the clear lens meets the black housing. With a 2000, you should have gray.
I think he means the interior lights, PM Gray, he changed his bulbs out so I can imagine he knows how to do it.
If it's the interior bulbs, then it's easy. Remove the panel around the switches for the dome lights, but remember the harness is still plugged in. For the doors, just remove the panel partway, the screws on the bottom should be enough. The one under the glove box has a panel that needs to be removed IIRC.
It is hard as hell to get that thing down from the ceiling of the car. So can you tell me how to get that thing down please. Those white bright ligths are killing me.
