Info on where to buy V6 5sp FLYWHEEL ??
Right on the Mark
here
I searched all 3 posts and no one says where they got theirs from. Any info on where to call? All peeps would say was it was in Ohio. Thanks Frank
Aftermarket manufacturers may be your best bet. Some years ago, I did a hybrid 2300 Ford four to a Doug Nash 5-speed. This necessitated both a modified Lakewood scattershield, and also a flywheel that attached to the four cylinder crank and took a clutch intended for a Boss 302 V-8. All it took was a call to McLeod to get the flywheel. And it cost the same amount as a catalog item. Good Luck!
KS
Lol it took 4 hours of calling around for my trans shop to find one... EXPENSIVE.
How much?
went to go check it out the car this morning, car is in bad shape rust wholes in the frame just terrible the bracket I'm looking for was on his car it almost disintegrated in my hands as i felt it. I can ask him for you but yeah...
If you want a used one I could sell you my used one. It's probably in the same condition or better then that one that guy is parting out.
I found it, $735.15.
FML...
$1521.68 including clutch kit, labor, and flywheel.
Wow, I'm going to do mine for less then half that. Labor blows, that's why I do it myself.
Just an FYI, I bought a Sacks clutch kit. The parts are identical to the Luk that came out, in fact the pressure plate says Luk on it. They didn't ship it with a alignment tool but I had them send me one at no extra charge.
